Schematics license error
MS_Santos
Hello, I have generated a new Schematics license, when the machines try to access it this error appears, what can I do?
Dale_Rosema
(To:MS_Santos)
Call your VAR and have them help walk you through licensing.
6 REPLIES 6
Dale_Rosema
(To:MS_Santos)
But the license is correct, I generated it successfully.
Dale_Rosema
(To:MS_Santos)
In a small company (2 seats), my VAR walks me through everything until the machine is working properly.
It was working normally, as the license expired I had to generate a new one - simple procedure
Dale_Rosema
(To:MS_Santos)
Glad you got it to work then.
Hello @MS_Santos
It looks like you have found an answer to your question. If so, could you please mark the appropriate reply as the Accepted Solution.
Vivek N.
Community Moderation Team.
