Hello, I have generated a new Schematics license, when the machines try to access it this error appears, what can I do?
Call your VAR and have them help walk you through licensing.
But the license is correct, I generated it successfully.
In a small company (2 seats), my VAR walks me through everything until the machine is working properly.
It was working normally, as the license expired I had to generate a new one - simple procedure
Glad you got it to work then.
Hello @MS_Santos,
It looks like you have found an answer to your question. If so, could you please mark the appropriate reply as the Accepted Solution.
Vivek N.
Community Moderation Team.
