Search Path very slow
SOLVED
Amethyst
Hello everybody,
With Creo Parametric I have a config that through search path allows me to search for components in another folder (libraries)
I put myself in the workbook, which inevitably contains about 1000 codes.
The problem is that when the CAD does not find a model because it is in libraries, it takes an eternity to understand it before moving on to the library folder.
It seems because there are so many files
It's normal?? Do you want us to be the only ones working with folders with many codes and the search path?
1 ACCEPTED SOLUTION
Re: Search Path very slow
@Matteo_1987 wrote:
Good morning,
I use only one search path in a library folder that contains about 1000 codes.
Attached is the config .pro file.
Matteo.
tip no1.
Rename your config.pro
Create config.pro containing single line - see below
search_path j:\cfg_flat_bag\librerie
tip no2.
Create copy of your config.pro and remove two lines - see below
instance_search_exhaustive YES
pro_library_dir wtpub://PDMLink/Prodotti/FLAT_BAG/Libreria/Componenti standard
Martin Hanák
7 REPLIES 7
Searching that many folders for as file is very time consuming and there is no way around the delay as the system tries to find your file in a library that is at the bottom of your search path listing.
The way to cure it is to utilize a PDM system, like Windchill, where the database knows the location of each file and does not have to do a massive directory search.
The function of PDM is already clear to me and this is not the case for using it.
I'm talking about a single search path for a folder that acts as a library.
I have already tried other config with more than one search path and it has never been so slow.
Are there other possible variables / options to be set at Creo level?
Could it depend on the server, firewall, antivirus, etc.?
Greetings,
Thank you.
Highlighted
Server, firewall and antivirus can all have an impact on retrieving files.
Creo will search your local directory where the assembly is loaded from and then move to the search path, if it has not found its files. What is your search path line in your config.pro? Does it point to a single folder or use a wildcard search for sub-folders?
Is this a new set-up that is slow compared to older ones that you have used? What has changed in your environment?
Greetings,
Thank you.
Q1: Do you use search_path or search_path_file option in config.pro ?
Q2: Do you use UNC path or mapped drive when specifying the path ?
Martin Hanák
Good morning,
Matteo.
@Matteo_1987 wrote:
Good morning,
Matteo.
tip no1.
tip no2.
Martin Hanák
If you are using Windchill/PDMlnk, why are you using search paths?
Put your library files in Windchill and do not use a disk folder.
FYI
You have your pro_format_dir pointing to a disk folder. This should always point to a Windchill location so when creating a drawing, Windchill does not think the format is a new file in your workspace.
