I use to be able to use the send to pull down to send file quickly to colleagues. Now when I use it Vista tries to configue a new email account. I looked at the registry editor and Outlook does not show up as the default email system. I go through the "new" vista set defaults applet in the control panel and set it as a default but it still doesn't show up in the registry. The send command seems to work with all other programs (Microsoft or otherwise) except Wildfire 3.0 and 4.0? Does Vista set up this default differently?
Has anyone seen this before?
Thanks in advance for any help you can give me.
Stephen
