Set PARTNO with relation?
raviles
Folks,
I understand that the system variable 'PTC_MFG_PRM_PARTNO' contains the PARTNO which is output in the CL file, like so in red:
$$*          Pro/CLfile  Version 2.0 - M100
$$-> MFGNO / 12345_67890_BOLSTER_PLATE
PARTNO / 12345-67890 BOLSTER PLATE
$$-> FEATNO / 48
MACHIN / UNCX01, 1
$$-> CUTCOM_GEOMETRY_TYPE / OUTPUT_ON_CENTER
UNITS / MM
Is there a way to set or define 'PTC_MFG_PRM_PARTNO' with a relation? I tried doing this but I received a "Verify Relations" error message.
Ray Aviles
1 ACCEPTED SOLUTION
gkoch
1-Newbie
(To:raviles)
Hello Ramon,
PARTNO output is based on operation parameter PARTNO or - if the parameter is empty ( - ) the model name will be output.
I assume the parameter PTC_MFG_PRM_PARTNO is just internally used and hence is read only. See article CS185968
Basically it should be possible to drive PARTNO with a relation like: PARTNO:FID_<operation ID> = "whateveryoulike"
However, it seems the mechanisms of CLDATA generation requires an extra trigger for the change to take effect, i.e. use Edit Definition to see CLDATA changed.
Gunter
6 REPLIES 6
KenFarley
(To:raviles)
You gave us the error message, but didn't tell us what relation caused it. Was it a syntax error, missing quote? We don't know.
I would think that a normal relation like the following should work
PTC_MFG_PRM_PARTNO = "My Part Number"
Judging from the line in the CL file it looks like this parameter is a STRING type, so this should work.
raviles
(To:KenFarley)
Ken,
I agree, the 'Verify Relations' error message is pretty vague. The attached picture clarifies the problem, and the source parameter is a string. I also tried a string of text as in your example, but it appears that Creo doesn't like us messing with this parameter.
Ray Aviles
KenFarley
(To:raviles)
Seems like a situation where some other file is setting the value and thus overwrites any change made outside of the manufacturing module? I know in the past I've changed that particular parameter, but in the options setting part of the program.
raviles
(To:KenFarley)
Ken,
I'm not sure what would prevent setting the PARTNO with a relation. Use of a relation to automatically set PARTNO instead of manually entering text in the PARTNO text box makes sense to me.
Ray Aviles
gkoch
1-Newbie
(To:raviles)
Hello Ramon,
Gunter
raviles
(To:gkoch)
Gunter,
Thanks for the information. I read the article and posted my two cents. I'll try your suggestion and post my results.
Ray Aviles
