Setting Background color to Black
MukaSingh
I am trying to set my background color in my work area to black and it always reverts back to "ProE. Is there any other way to set this? I set it to black and save the config file and when I start back ProE it goes back to the default color.
1 REPLY 1
The file you need to change your background is called SYSCOL.SCL your .DTL file points to this file when it loads
there is a process to changing your background
first things first
go to tools/options
the command is called System_Color_File
you need to find out were that is pointing to. This is very important
as an example mine is pointing to d:\Work\SYSCOL.SCL
So what you need to do is go to View/Display Settings/System Colors
Change your background colors at the very bottom, then before you exit go to the top of the menu
and go to File/Save, this will save your SYSCOL.SCL file which saves your background color.
now make sure when you save it to save it to were your .dtl file is pointing
and that should take care of it. no need to save the dtl file unless you want to change the path to were your SYSCOL.SCL is located
Also i uploaded a document that describes all of the pro-e config files.
http://communities.ptc.com/docs/DOC-1357
