Setting for the assembly preview window
uklemme
8-Gravel
Hello everyone,
I'd like to know if there is a possibility to set the size of the preview window that appears when adding a component to an assembly. Maybe a config-setting or something like this.
Thank you in advance!
Best regards
Uwe
PeterKehoe
(To:uklemme)
There is a command called "Aux 3D Viewport" (in version 17 it is in the Window menu, in version 18.1 it is in the Window group in the View tab). That command brings up a 3D viewport. I found that if you adjust the size of that viewport and then close it, the next time Annotation needs a 3D viewport it will be the same size as when you closed it last. And, it remembers the size between sessions.
