Settings for flats
dtornier
Settings for flats
Dear all,
I have a problem with my flats in creo parametric 2.0
If I turn my model, the flats are always hidden.
Is it possible to change something in the settings so that the problem does not recur?
Thank you.
5 REPLIES 5
can you attach some pictures to better describe your problem ?
Martin Hanak
Martin Hanák
The first one is without turning my model. The second one is when i turn my model around. The flats are gone and i would like to see them everytime.
to see datum planes during model rotation, add the following option at the end of config.pro file
spin_with_part_entities YES
Martin Hanak
Martin Hanák
OK
Thank you
Dale_Rosema
(To:dtornier)
If this solved your problem, don't forget to mark Martin's answer as correct.
Thanks, Dale
