Shade Quality Config Option?
dgschaefer
There isn't one, unfortunately. You can make a mapkey to set it:
mapkey sq1 @MAPKEY_LABELShade quality 10;\
mapkey(continued) ~ Select `main_dlg_cur` `MenuBar1`1 `View`;\
mapkey(continued) ~ Close `main_dlg_cur` `MenuBar1`;\
mapkey(continued) ~ Select `main_dlg_cur` `View.cb_view_advanced`;\
mapkey(continued) ~ Close `main_dlg_cur` `View.cb_view_advanced`;\
mapkey(continued) ~ Activate `main_dlg_cur` `psh_view_mdldisp`;\
mapkey(continued) ~ Update `modeldisplay` `ModDsply_SB_ShadeQlty`10 ;\
mapkey(continued) ~ Activate `modeldisplay` `ModDsply_PB_OK`;
mapkey sq3 @MAPKEY_LABELShade quality 3;\
mapkey(continued) ~ Update `modeldisplay` `ModDsply_SB_ShadeQlty`3 ;\
You can make any other level you want by changing the number in the
second to last line.
Doug Schaefer
LinkedIn
What is the , is there a, config-option with which I can set the shade quality to another valve than the default value
(Mouse clicks : view | Display settings | model display | Shade tab | quality)
I have a use who needs/wants it to be higher than the default value of 3
TomU
(To:dgschaefer)
shade_quality 10
Also take a look at:
edge_display_quality very_high
smooth_lines yes
Tom Uminn
Systems Administrator
trans-matic Mfg.
616-820-2499
-<">mailto:->
Attention: Creo 7.0 Customers
Please consider upgrading
End of Life announcement here.
