Show/Erase Creo 3
cdown
7-Bedrock
Show/Erase Creo 3
Having had to go to Creo 3 without proper testing I am struggling.
In drawing mode when you do a show erase for axis (assembly file) is shows no axis!! i can only get axis to show if I go through individual parts in the model tree.....this can't be right, again is this an new config option??
Does anyone have a detailed list of the config changes for Creo3 that they would be willing to share?
TomU
(To:cdown)
Check the config option “show_axes_by_view_scope”. It defaults to “top_model_only” and may be causing the behavior you’re seeing.
Tom U.
