Silent Uninstallation of PTC Portmapper
dachammer
Wanting to know if this uninstall can be made quiet no user prompts. I have tried the following command line switches
C:\Program Files\PTC\PTC Portmapper\bin\uninstall.exe /silent
C:\Program Files\PTC\PTC Portmapper\bin\uninstall.exe /quiet
Creo 2.0 can be uninstalled using following command
C:\Program Files (x86)\PTC\Creo 2.0\Parametric\bin\uninstall.exe –quiet
See https://support.ptc.com/appserver/cs/view/solution.jsp?n=CS127329
You can try C:\Program Files\PTC\PTC Portmapper\bin\uninstall.exe –quiet
Or you can contact PTC Support as last instance ...
Martin Hanak
Martin Hanák
7 REPLIES 7
David,
I am just curious.... Why did you install PTC Portmapper ?
Martin Hanak
Martin Hanák
I am unsure as to why it was installed. It wasn't something I specifically installed must have came in with something else that was selected during our install.
According to my knowledge, PTC Portmapper is necessary to install when user uses CADDS5 system. So uninstall it using Windows UI and never install again.
Martin Hanák
I need a silent uninstall string. Windows UI is not an option for my customers.
Martin Hanak
Martin Hanák
I don't have the uninstall for the PTC Portmapper however I have used the following for other PTC components. I think it would be similar to the Parametric and Simulate removal commands:
start /w "" "%UNINSTALLPATH%" -quiet
Here is code from my Creo installer that removes the old stuff
echo Starting removal of Creo Platform...>>%LOG%
start /w msiexec.exe /x "C:\ptc\Creo 2.0\Common Files\%OLDBUILD%\install\addon\creoagent_32_64.msi" /q
rem sleep 5 seconds (5 pings at 1000 milliseconds per ping)
ping 127.0.0.1 -n 5 -w 1000 > NUL
echo Starting removal of Thumbnail Viewer...>>%LOG%
start /w msiexec.exe /x "C:\ptc\Creo 2.0\Common Files\%OLDBUILD%\install\addon\Thumbviewer_32_64.msi" /q
echo Starting removal of Product View 9.0...>>%LOG%
start /w msiexec.exe /x{C2727593-C9AF-41E0-99C6-B004393564A1} /q
echo Starting removal of Creo View Express...>>%LOG%
start /w msiexec.exe /x "C:\ptc\Creo 2.0\Common Files\%OLDBUILD%\install\addon\pvx32_64\pvexpress\CreoView_Express_32_64.msi" /q
echo Starting removal of Arbortext IsoView 7.3...>>%LOG%
start /w msiexec.exe /x {DE52A69A-978A-480A-82F7-E17C50F98EC6} /q
echo Starting removal of Creo Quality Agent...>>%LOG%
start /w msiexec.exe /x {5B7F8A19-AF71-4517-B49C-683AFC5B639C} /q
(set PARAMETRICPATH=C:\ptc\Creo 2.0\Parametric\bin\uninstall.exe)
(set SIMULATEPATH=C:\ptc\Creo 2.0\Simulate\bin\uninstall.exe)
echo Starting removal of Creo Parametric...>>%LOG%
start /w "" "%PARAMETRICPATH%" -quiet
rem sleep 20 seconds (20 pings at 1000 milliseconds per ping) - required to prevent error
ping 127.0.0.1 -n 20 -w 1000 > NUL
echo Starting removal of Creo Simulate...>>%LOG%
start /w "" "%SIMULATEPATH%" -quiet
Thank you great information!
