is there a possibility to install Flexnet license server silently on Windows Server Core 2022?
or even install it on Windows Server Core 2022?
br Bernhard
Hi @bmüller,
Thank you for your question.
Your post appears that has not yet received any response. I am replying to raise awareness. Hopefully, another community member will be able to help.
Also, feel free to add any additional information you think might be relevant. It sometimes helps to have screenshots to better understand what you are trying to do. Please refer to this guideline to make your questions more likely to receive a quick and useful answer.
Best regards,
i am also intrested in a silent install for FLEXnet Admin Version 11.19.6.1.
Is there a known way to do it?
I know the way to install PTC Creo Parametric silent for example is to start the setup.exe with the -xml parameters. E.g.:
"SOURCEPATH\"setup.exe" -xml "SOURCEPATH\pim\xml\creobase.xml" -xml "SOURCEPATH\pim\xml\pma.xml"
In the source from the FLEXnet Admin is also a pim\xml\flexadmin.xml file, but when i start the setup.exe from the source of FLEXnet Admin with the parameter to the given .xml-file i always get an errorcode -1.
I think this has to do with the missing license.dat file which i need to browse in the gui installation.
Is there a way to define the license.dat file in the pim\xml\flexadmin.xml or to define the license.dat file as a parameter?
Thank you in advance.
Best regards
Oliver
