Silhouette curve creation in Creo 2
snguyen
Good morning,
I have a weird part that will have a crazy split line and
would like to create a silhouette curve of where I think the split line will
be on the surface but at the moment I do not have access to mold license. I
know in ProMold I can create it but is there a way to create it in a regular
flex engineer license?
This is the view I want the curve to fall on the part. I tried to create a
sketch and then project it to the surface but some areas of the part I
cannot use the project on some of the edges of the part.
Thanks.
Son T. Nguyen
108 W. 2nd Street
Assaria, Kansas 67416
785-667-7763
6 REPLIES 6
1 copy all exterior surfs.
2 Use a surface trim operation via plane- trimming the quilt created in 1.
3 normal of the trimming plane should be coincident with your pull vector
4. i believe there is a fly-out or option to trim via silhouette
5. perform the trim.
6. create a composite datum curve on the trimmed edge of the quilt.
7. layer off the quilt....to only see the curve..
On Wed, Feb 11, 2015 at 9:33 AM, Son Nguyen <->
wrote:
> Good morning,
> will be on the surface but at the moment I do not have access to mold
> license. I know in ProMold I can create it but is there a way to create it
> in a regular flex engineer license?
> Thanks.
> Son T. Nguyen
> 108 W. 2nd Street
> 785-667-7763
cprice
6-Contributor
(To:snguyen)
Try placing the udf on the part. (silh_curve.gph)
This should help.
Charlie Price
Strategic Technical Services LLC
Phone 330.887.9295 Desk/Mobile/FAX
Main 888.479.1566x127
charlie.price@stechservices.com
Copy the geometry.
Paste the geometry.
Create a surface extrude where you want the parting line.
Create an intersect feature between the extruded surface and the copied geometry.
I have also used Pete’s method in the past, with success.
Bob
Thank you for all the suggestions and I got the curve I needed with using this method recommended by Pete. I did not get a chance to try Charlie’s method. I will try that one when I get this project done.
Thanks.
You can find the silhouette trim feature in the trim command.
Make sure to choose a directional surface (in this case a datum plane) to use as a reference.
Please see the attached image.
