1 copy all exterior surfs.
2 Use a surface trim operation via plane- trimming the quilt created in 1.
3 normal of the trimming plane should be coincident with your pull vector
4. i believe there is a fly-out or option to trim via silhouette
5. perform the trim.
6. create a composite datum curve on the trimmed edge of the quilt.
7. layer off the quilt....to only see the curve..
On Wed, Feb 11, 2015 at 9:33 AM, Son Nguyen <->
wrote:
> Good morning,
> I have a weird part that will have a crazy split line and
> would like to create a silhouette curve of where I think the split line
> will be on the surface but at the moment I do not have access to mold
> license. I know in ProMold I can create it but is there a way to create it
> in a regular flex engineer license?
> This is the view I want the curve to fall on the part. I tried to create a
> sketch and then project it to the surface but some areas of the part I
> cannot use the project on some of the edges of the part.
> Thanks.
> Son T. Nguyen
> 108 W. 2nd Street
> Assaria, Kansas 67416
> 785-667-7763
