All,
I have a part that has several instances. With toolkit I am opening one
of those instances and retrieving a simp rep. Then I output an ACIS
file and then I want to clear my memory of everything except the generic
part that I started with. How do I do this? I am unable to
successfully call ProFaminstanceErase I think because I have a simp rep
of the instance open. However when I call ProMdlErase on the ProPart
simp rep handle it crashes Pro. Can someone give me some advice on
activating/retrieving a simp rep of an instance of a part and then
erasing it? Here is my code to output the ACIS file. I am not trying
to erase the instance in the function. I try and erase the instance in
the calling function.
ProError Model3D::OutputACIS(ProMdl mdlInstance, wstring symbolValue,
ProSimprep simpRep) {
char *szFuncName
= "OutputACIS()";
ProError pro_error
= PRO_TK_NO_ERROR;
ProPart pro_partSimpRep
= NULL;
ProFamilyName pro_wszMdlName;
ProName pro_wszSimpRepName;
ProSimprepType pro_simpRepType;
ProIntf3DExportType pro_intf3DExportType
= PRO_INTF_EXPORT_SAT;
ProOutputAssemblyConfiguration pro_outputAsmConfig
= PRO_OUTPUT_ASSEMBLY_FLAT_FILE;
ProBoolean pro_bIsSupported
= PRO_B_FALSE;
ProOutputBrepRepresentation pro_bRep;
ProOutputInclusion pro_outputInclusion;
ProOutputLayerOptions pro_outputLayerOptions;
ProSelection pro_sel;
ProPath pro_wszFileName;
ProGeomitem pro_geomItem;
ProCsys pro_csys;
ProSimprep pro_simpRepMaster;
//Get the name of the simp rep
pro_error = ProModelitemNameGet((ProModelitem*)&simpRep,
pro_wszSimpRepName);
PROUTIL_CALL_REPORT("ProModelitemNameGet()", szFuncName,
pro_error, pro_error!=PRO_TK_NO_ERROR);
//Activate the simp rep
if(m_pro_mdlType == PRO_MDL_PART) {
//Get the simp rep type
pro_error = ProSimprepTypeGet(&simpRep, &pro_simpRepType);
PROUTIL_CALL_REPORT("ProSimprepTypeGet()", szFuncName,
//Get the name of the instance
pro_error = ProMdlNameGet(mdlInstance, pro_wszMdlName);
PROUTIL_CALL_REPORT("ProMdlNameGet()", szFuncName,
//Retrieve the simp rep
pro_error = ProPartSimprepRetrieve(pro_wszMdlName,
pro_simpRepType, pro_wszSimpRepName, &pro_partSimpRep);
PROUTIL_CALL_REPORT("ProPartSimprepRetrieve()", szFuncName,
else if(m_pro_mdlType == PRO_MDL_ASSEMBLY) {
pro_error = ProSimprepActivate((ProSolid)mdlInstance,
&simpRep);
PROUTIL_CALL_REPORT("ProSimprepActivate()", szFuncName,
pro_partSimpRep = (ProPart)mdlInstance;
//Display the simp rep
pro_error = ProMdlDisplay((ProMdl)pro_partSimpRep);
PROUTIL_CALL_REPORT("ProMdlDisplay()", szFuncName, pro_error,
//Build the output filename
swprintf(pro_wszFileName, L"%s_%s_%s", symbolValue.c_str(),
m_wstrLayerValue.c_str(), wcsstr(pro_wszSimpRepName, L"_") + 1);
//Verify that the assembly configuration is valid for exporting
and IGES file
pro_error =
ProOutputAssemblyConfigurationIsSupported(pro_intf3DExportType,
pro_outputAsmConfig, &pro_bIsSupported);
PROUTIL_CALL_REPORT("ProOutputAssemblyConfigurationIsSupported()",
szFuncName, pro_error, pro_error!=PRO_TK_NO_ERROR);
if(pro_bIsSupported == PRO_B_FALSE)
return PRO_TK_BAD_INPUTS;
//Allocate geometry flags structure
pro_error = ProOutputBrepRepresentationAlloc(&pro_bRep);
PROUTIL_CALL_REPORT("ProOutputBrepRepresentationAlloc()",
//Set the geometry flags structure
pro_error = ProOutputBrepRepresentationFlagsSet(pro_bRep,
PRO_B_FALSE, PRO_B_FALSE, PRO_B_TRUE, PRO_B_FALSE);
PROUTIL_CALL_REPORT("ProOutputBrepRepresentationFlagsSet ()",
//Verify that these flags are supported
pro_error =
ProOutputBrepRepresentationIsSupported(pro_intf3DExportType, pro_bRep,
&pro_bIsSupported);
PROUTIL_CALL_REPORT("ProOutputBrepRepresentationIsSupported()",
//Allocate inclusion flags structure
pro_error = ProOutputInclusionAlloc(&pro_outputInclusion);
PROUTIL_CALL_REPORT("ProOutputInclusionAlloc()", szFuncName,
//Set the inclusion flags
pro_error = ProOutputInclusionFlagsSet(pro_outputInclusion,
PRO_B_FALSE, PRO_B_FALSE, PRO_B_FALSE);
PROUTIL_CALL_REPORT("ProOutputInclusionFlagsSet()", szFuncName,
//Allocate the layer options structure
pro_error = ProOutputLayerOptionsAlloc(&pro_outputLayerOptions);
PROUTIL_CALL_REPORT("ProOutputLayerOptionsAlloc()", szFuncName,
//Set the layer options
pro_error = ProOutputLayerOptionsAutoidSet(pro_outputLayerOptions,
PRO_B_TRUE);
PROUTIL_CALL_REPORT("ProOutputLayerOptionsAutoidSet()",
//Get the csys for this simp rep
pro_csys = GetCsys(pro_partSimpRep);
//Convert the cys to a geomitem
pro_error = ProCsysToGeomitem((ProSolid)pro_partSimpRep, pro_csys,
&pro_geomItem);
PROUTIL_CALL_REPORT("ProCsysToGeomitem()", szFuncName, pro_error,
//Allocate a selection object for the csys geomitem
pro_error = ProSelectionAlloc(NULL, (ProModelitem*)&pro_geomItem,
&pro_sel);
PROUTIL_CALL_REPORT("ProSelectionAlloc()", szFuncName, pro_error,
//Output the IGES file
pro_error = ProIntf3DFileWrite((ProSolid)pro_partSimpRep,
pro_intf3DExportType, pro_wszFileName, pro_outputAsmConfig, pro_sel,
pro_bRep, pro_outputInclusion, pro_outputLayerOptions);
PROUTIL_CALL_REPORT("ProIntf3DFileWrite()", szFuncName, pro_error,
//Free the csys selection object
pro_error = ProSelectionFree(&pro_sel);
PROUTIL_CALL_REPORT("ProSelectionFree()", szFuncName, pro_error,
//Free the layer options structure
pro_error = ProOutputLayerOptionsFree(pro_outputLayerOptions);
PROUTIL_CALL_REPORT("ProOutputLayerOptionsFree ()", szFuncName,
//Free the inclusion flags structure
pro_error = ProOutputInclusionFree(pro_outputInclusion);
PROUTIL_CALL_REPORT("ProOutputInclusionFree()", szFuncName,
//Free the geometry flags structure
pro_error = ProOutputBrepRepresentationFree(pro_bRep);
PROUTIL_CALL_REPORT("ProOutputBrepRepresentationFree()",
return PRO_TK_NO_ERROR;
Patrick Williams
Application Engineer
Steelcase Inc.
