Simplified Rep Window
EricHuffman
2-Explorer
Gurus,
Is there a config option for the separate window when creating and redefining simplified reps?
If so, what is it so I can turn it off.
I want to redefine my simplified reps in the main window...not the little pop up window.
CREO 2.0 m110
Windchill 10.0 m030
Eric
StephenW
(To:EricHuffman)
New_wf5_simp_rep_ui NO
Takes you back to the old style simplified rep process.
Eric
Had you played with some options?
Lower left icons in CREO 2 Simplified Rep GUI
Glasses turn on\off mini window
Left icon changes layout
Also
Select from “Main Window” is a pick option from the Select pull down
To be honest I do use the setting (new_wf5_simp_rep_ui no)
I find it less cluttering, and when I’m on a laptop I need the room.
Jscott
Jeff Lippeth ▪ Mold Design Engineer
NyproMold, Inc.
▪ T 847.855.2226
