Hi
I have stuck in one condition, suppose if i have many numbers of start file for different parts , which start file is to selected is controlled in condition.mcc file , now if i want to make only one start file so i have to write all the attribute inside that single start file. now when i run model check all the attributes present inside the new start file assigned to the parts.can we control the number of attribute and relation to assigned in part by any condition.
If I understand your question right, the answer is no. You will have to use multiple start files to control which parameters get added at each condition. There is no logic control within the start file structure.
Hi
in model check Is it possible to use different config folder located at (C:\Program Files\PTC\Creo 3.0\M060\Common Files\modchk\text\usascii\config) to be use in different condition i.e according to condition the config folder changes, if possible tell me.
Nimesh,
ModelCHECK configuration files will be a single collection, cannot define the folders on any of the conditions.
