does anyone know a way to manipulate the size of the creo startup configuration window where the use chooses his configuration/license to start Creo 2.0 Parametric?
I would like that this window is larger so the user can see all options at once without the need to scroll within the window.
Axel
Hi Axel,
set configuration option:
open_window_maximized yes
Hello Vladimir,
I did not find this function in the config.pro
I use the property of the icon AUNCH of Creo by choosing:
Run: Maximized
Cordially.
Denis
Hi Denis
The configuration option: open_window_maximized - is hidden option ![]()
You can use it - here is my configuration file:
Set the option:
open_window_maximized yes >> save config.pro file and restart Creo.
Vladimir
Hello Vladimir,
Thank you for this information.
I thought it would find it among the hidden features.
Cordially.
Denis
It shows up in Olaf's list if you list all config.pro options.
Dear all,
I think there was a misunderstanding of my initial Question.
I meant the size of the window shown below if I start Creo (parametric.exe), where I can choose the Startup Configuration I want to use. The initial size is like shown below, so I see only a part of our Startup Configuration at first und need to scroll down to see the other Startup Configuration.
The question was if it is possibel to influnce the size of this window at the beginning so that I can see all Startup Configuration at once and I do not need to scroll.
Axel
I think, that it is not possible, sorry.
Vladimir
Note: you can create custom html file and run this several Startup option with customized window.
Vladimir,
can you publish an example of such HTML file ?
Martin Hanak
Hi Folks,
if you know HTML code and js script - you can combine your knowledge and create something like this ![]()
Sorry, but it is forbidden to copy of *hta and *js script of this utility ... but I know that you can do it alone.
Have a nice time,
Vladimir
Another thing you could do, which I have done, is reorder the options so that the ones you use most are at the top.
How do you reorder the options?
