Sloooow Pro/E Launch
gwalker
Every oncein a while we have multiple users all complaining that Pro/E won't open. Xtop.exe is running in task manager and a license has be locked to the user but there is not graphic interface (no indication that Pro/E is open). After about 10 to 15 minutes (highly variable) Pro/E will finally open.
The last two times I tried to troubleshoot this problem I encountered an interesting coincidence. When I tried to access PTC.com to submit a call or search the knowledge base the PTC site was extremely slow (I had this problem again this morning). Other web sites work fine.
Is there any behind the scenes connection between the Pro/E application and PTC.com? I have changed the embedded web browser’s start page to our company Intranet. Am I missing something?
Has anyone else had this excruciatingly slow launch from Pro/E? Have you identified the cause?
Gordon Walker
Pro/E Administrator
(804)451-2410
Cell: (804) 615-4877
<u>Gordon.Walker@HillPHOENIX.com</u>
StephenW
(To:gwalker)
We seem to have a slow launch, about a minute (no where near as bad as yours). Our admin says it's because they moved the intralink and license server to another facility, still within our network, but a different physical building across town. I did the same thing, I changed my embedded web browser to about:none to help. It didn't.
Hope you get good answers and please share them with the rest of us.
Gordon,
By default, Pro-e will link to ptc.com in the integrated web browser, and it typically is the cause of this fluctuation and directly related to the slow processing of the ptc.com website you encountered. Sometimes are faster than others. To avoid this, set the config option:
i.e. web_browser_homepage c:\users\dmrobers
to your start in directly or your company home page if you prefer to eliminate this bottleneck. FYI, you may want to save that ptc site to favorites first though because it does have a lot of handy information and tutorials AND is hard to find once you have deleted the link.
Good luck,
David M. Robers
Vice-president of Sales
Diversified Design Dynamics
6039 Schumacher Park Drive
West Chester, OH 45069
Better yet, set the config.pro option web_browser_homepage = about:blank - this will prevent Pro/E from starting with any link.
RonThellen
(To:gwalker)
Gordon,
Pro/E is indeed communicating with PTC during startup, even if you have
the embedded browser pointing to a local web page. They are checking
for updates to the "Connections" tab.
Here is an entry I have in my config.pro with related comments. You
might want to add this to yours and see if it corrects your problem.
!web_enable_subscription allows Pro/E to go out to the "Connections"
! favorites to determine if any have been updated. If so, it displays
them
! in BOLD font. The connections favorites are rarely, if ever, used.
! So, don't waste time checking them. This happens during Pro/E startup
! and can really slow startup if there are any delays or slowdowns
! in web performance.
web_enable_subscription no
Ron Thellen
CAD Administrator
Engineering & Manufacturing Applications
Government Communications Systems Division
Harris Corporation
321-729-7502
