Dear All,
This is Haris and recently i join PTC community.
i got problem during installation Creo 3.0. before that i was installing Creo 2.0 there was not any problem after that i removed Creo 2.0 and tried to install Creo 3.0. when i drag and drop license file it didn't accept and status answer was invalid file and formate. then again i tried several time but i failed. could anybody help to solve this issue?
awaiting
regard
Muhammad Haris@
Dear All,
i have found solution my self thanks!
Regard
Muhammad Haris
Muhammad,
You may mark your answer as correct answer as you found the solution on own.
