Community Tip - If community subscription notifications are filling up your inbox you can set up a daily digest and get all your notifications in a single email.
X
Was missing. Don't know why ptcsetup is not creating this variable.
BTW, spaces do not matter.
On Mon, Sep 24, 2012 at 9:19 AM, Michael Gamber <->wrote:
> this is what happens when I turn echo off and run it. > > C:\caduser\212003>purge > > C:\caduser\212003>REM @echo off > > C:\caduser\212003>set MC=unset > > C:\caduser\212003>if " == "INTEL_64" set MC=ia64_nt > > C:\caduser\212003>if " == "INTEL_486" set MC=i486_nt > > C:\caduser\212003>if "AMD64" == "IA64" set MC=ia64_nt > > C:\caduser\212003>if "AMD64" == "AMD64" set MC=x86e_win64 > > C:\caduser\212003>if "AMD64" == "x86" set MC=i486_nt > > C:\caduser\212003>REM cygwin sets this on 64bit OS > > C:\caduser\212003>if " == "AMD64" set MC=x86e_win64 > > C:\caduser\212003>if not "x86e_win64" == "unset" goto mc_done > > C:\caduser\212003>if NOT " == " goto creoset > > C:\caduser\212003>set APPDIR=C:\caduser\212003\.. > > C:\caduser\212003>set cf=C:\caduser\212003\..\.. > > C:\caduser\212003>set PRODIR=C:\caduser\212003\..\..\Common Files\M020 > > C:\caduser\212003>goto pdirset > > C:\caduser\212003>set PRO_MACHINE_TYPE=x86e_win64 > > C:\caduser\212003>set start_cmd=start " > > C:\caduser\212003>set PRO_DIRECTORY=C:\caduser\212003\..\..\Common > Files\M020 > > C:\caduser\212003>set CREOAPP_DIRECTORY=C:\caduser\212003\.. > > C:\caduser\212003>if NOT "true" == " goto ptcpathset > > C:\caduser\212003>"C:\caduser\212003\..\..\Common > Files\M020\x86e_win64\obj\purg > e.exe" > The system cannot find the path specified. > > C:\caduser\212003>exit /B 3 > > > The SET APPDIR is getting set to the folder with my files, this cannot be > correct. Later in the batch you see it is looking for the common files down > under the folder I am trying to purge. > > I am on Windows 7 64 bit, Creo 2.0 m020. > I have run the reconfigure several times hoping it would correct itself. > Could someone that has this working with similar config copy and paste > their path to a reply? > This thread is inactive and closed by the PTC Community Management Team. If you would like to provide a reply and re-open this thread, please notify the moderator and reference the thread. You may also use "Start a topic" button to ask a new question. Please be sure to include what version of the PTC product you are using so another community member knowledgeable about your version may be able to assist.
