Solved purge not working? Creo 2.0 m020
lococnc
The environment variable
CREO_DIRECTORY
Was missing. Don't know why ptcsetup is not creating this variable.
BTW, spaces do not matter.
On Mon, Sep 24, 2012 at 9:19 AM, Michael Gamber
<->wrote:
> this is what happens when I turn echo off and run it.
> C:\caduser\212003>purge
> C:\caduser\212003>REM @echo off
> C:\caduser\212003>set MC=unset
> C:\caduser\212003>if " == "INTEL_64" set MC=ia64_nt
> C:\caduser\212003>if " == "INTEL_486" set MC=i486_nt
> C:\caduser\212003>if "AMD64" == "IA64" set MC=ia64_nt
> C:\caduser\212003>if "AMD64" == "AMD64" set MC=x86e_win64
> C:\caduser\212003>if "AMD64" == "x86" set MC=i486_nt
> C:\caduser\212003>REM cygwin sets this on 64bit OS
> C:\caduser\212003>if " == "AMD64" set MC=x86e_win64
> C:\caduser\212003>if not "x86e_win64" == "unset" goto mc_done
> C:\caduser\212003>if NOT " == " goto creoset
> C:\caduser\212003>set APPDIR=C:\caduser\212003\..
> C:\caduser\212003>set cf=C:\caduser\212003\..\..
> C:\caduser\212003>set PRODIR=C:\caduser\212003\..\..\Common Files\M020
> C:\caduser\212003>goto pdirset
> C:\caduser\212003>set PRO_MACHINE_TYPE=x86e_win64
> C:\caduser\212003>set start_cmd=start "
> C:\caduser\212003>set PRO_DIRECTORY=C:\caduser\212003\..\..\Common
> Files\M020
> C:\caduser\212003>set CREOAPP_DIRECTORY=C:\caduser\212003\..
> C:\caduser\212003>if NOT "true" == " goto ptcpathset
> C:\caduser\212003>"C:\caduser\212003\..\..\Common
> Files\M020\x86e_win64\obj\purg
> e.exe"
> The system cannot find the path specified.
> C:\caduser\212003>exit /B 3
> The SET APPDIR is getting set to the folder with my files, this cannot be
> correct. Later in the batch you see it is looking for the common files down
> under the folder I am trying to purge.
> I am on Windows 7 64 bit, Creo 2.0 m020.
> I have run the reconfigure several times hoping it would correct itself.
> Could someone that has this working with similar config copy and paste
> their path to a reply?
0 REPLIES 0
