Hello Guru's! (Help!)
We are going to be moving to a network install of Pro\Engineer, instead
of the client installs on each workstation that we are currently using.
I have a situation I could use some guidance on.
We currently have three locations, which use five different loadpoint
config.pro's and three different config.sup files. This is currently
handled with batch files.
The general users at each of our three facilities have a general batch
file which runs when they launch Pro\E and/or Intralink that loads the
general config.pro and config.sup files for that facility into their
loadpoint\text folders.
If the user is a member of Packaging, their batch file loads the
packaging config.pro, if they are Industrial Design, they get the ID
config.pro
Since we are going to move to a network install, how do we handle this?
Do I have to install Pro\E three times for each facility? How do our
packaging and Industrial Design folks get their unique loadpoint\text
config files?
Black & Decker Hardware & Home Improvement
Michelle McMasters
Engineering Systems Administrator
michelle.mcmasters@bdhhi.com
Demonstrate Unyielding Integrity * Deliver on Commitments * Inspire
Excellence * Win through Teamwork
IMPORTANT NOTICE: This message is intended only for the use of the
individual or entity to which it is addressed. The message may contain
information that is privileged, confidential and exempt from disclosure
under applicable law. If you are not the intended recipient, you are
notified that any dissemination, distribution or copying of this
communication is prohibited. If you have received this communication in
error, please notify the sender immediately. Thank you
