After running the Spekan Purge utility, when attempting to open model 123.prt, I receive the message, "123.prt.1 is an invalid file". This has occurred on numerous files in numerous folders. Has anyone else encountered this and, if so, can you advise, please, the resolution to be able to open the models?
Hi Christopher,
I have no soluition since I have never encountered that problem after running the Spekan tool.
Just a try, remove the .1 extension and try to open it.
Do all processed elements have the .1 index? Or just the ones that are still in their initial state?
Hello Constantin,
Thank you for your reply. I tried removing the .1 extension but, unfortunately, to no avail. Yes, all processed elements have the .1 index as I had selected the "Rename last version to .1" option. Any other thoughts from yourself and the community would be appreciated.
