Hello all,
I am new to the Spekan sBatch tool (version 4.1) and was hoping some of you veterans might be able to help me out.
As a simple test, I tried to do the following:
-Use a .prt on my desktop to run a simple action on
-Have the tool write a mapkey that I can load into Creo
I can generate the spekan.pro file without issue, and I can load it into Creo as well. When I look at my mapkeys in creo, I show four additional mapkeys that were loaded in from the spekan.pro file:
-batchclose
-batchexit
-batchsave
-run
These are in addition to my mapkeys in my config file loaded during creo startup.
However, when I excecute the "-run" mapkey, nothing happens. The message area in Creo says "Playing mapkey -run...".
Any ideas as to what might be wrong?
Also, I noticed the tool produces the spekan.pro file AND another file called sBatch.pro. What is this file used for?
I have attached my spekan.pro file.
Andri
Creo 1.0 M050
Windchill 10.0 M030
Hi Andri,
Sbatch 4.1 works only in Wildfire, it hasn´t been updated to Creo.
The mapkeys from wildfire also don´t work in Creo, they have to be recreated.
You can use Creo Distributed Batch (Dbatch) to run a mapkey in multiple files, it´s free and it comes with Creo installation files. Here´s an example video:
http://communities.ptc.com/videos/3303
Some tasks come already defined like importing, exporting, plotting, etc.. You don´t need mapkeys for these.
Hope it helps.
Jose
Jose,
Clearly an oversight on my part - I didn't think sBatch cared if I was running Creo vs. WF, but obviously it does.
Since I still have Creo Elements 5.0, I tried running a sBatch mapkey with it, and it worked just fine!
I've tried using Creo Distributed Batch, and it worked - but the process was so slow and inefficient (for a PDF export of multiple .drws, Creo started and shutdown in between every export), in the end taking much longer than if I manually open each drawing and do a PDF export on each item. See this discussion. That's why I am looking for another way to do this.
Do you know if Distributed Batch allows you to generate a .pro mapkey file that can then be loaded into a running session of Creo, similar to how sBatch does it?
There has got to be a way to efficiently and "relatively" easily export hundreds of drawings, using Creo and Windchill!
Thanks for your help,
Andri
