anywhere i can download the stock, standard, unmodified, Creo 2.0 config.pro file.
In the <loadpoint>/text folder there are two <units>_config.pro files, called english_config.pro and metric_config.pro file that will be copied into a default config.pro file when you select your default units during initial installation. Those file remain in the text folder if you need to reference them.
Dan N.
There is no 'stock' config.pro file. There is a default file with the OOTB PTC settings that is loaded if there is no user file to override the default settings. This file is in the <loadpoint>/text folder and is named config.cdb. It has all of the possible config.pro settings with the options. DO NOT EDIT this file. There is a sample config.pro in that same folder.
Dan N.
I agree with Ben - there are hundreds of config options, most of which have a default value which can be seen in the config options window. The rest are customized, like which folder to store formats in, and can't have a default.
Basically, to get back to stock, delete or comment out any entries in the config.pro and config.sup.
