Start-Up Problem, "Configuration File Open Error"
ptc-3126397
I am using a university issued, student version of Wildfire 4.0 and after installation and attempting to launch I get the error message "Unable to launch Pro/Engineer because no valid configuration (*.psf) files were found. Please run "ptcsetup" from your installation "bin" directory and create a PTC Startup File. This is needed for Pro/Engineer to launch successfully" I have launched the setup numerous times and used different config directories, but to no avail. Any help on the matter would be greatly appreciated.
I have also been having this exact problem after installing the software. Have you found a solution yet? Thank you, Stephen
Martin Hanák
