Student Pro E install problem...
ptc-3230159
I received the student edition of Pro E. I have the product key that came with the Cd's. When I enter the code, and my user name and password, and submit it, I get an error that says "the connection has timed out, please try again later". I have just signed up this evening on PTC's website, and I wonder if there is some sort of waiting period... or something. I have tried this on three different computers all connected to the internet, and I get the same error. Thanks. Rob
6 REPLIES 6
ye hey rob how ya doin. i got the exact same message. so i decided to use the offline licensed version everything is exactly the same. request an offline license to be sent to u via email. about a 2 hour wait. then when u browse to place the offline license in to the install screen, make sure it is set on dat. files not all files so it can be seen. after that it should be alrite
Thanks Peter. I have done that, and have successfully started Pro E. Though, I have one issue. I get this error when I start the program: "License request failed for feature PROE_StudentEdition4:-2: Invalid license file syntax". When I click "ok" it closes the program. What do I need to do to get this working properly? Rob
Martin Hanák
Martin, When I received my license code in my email, I had to copy and paste it into a WordPad document and save it as a txt file. When I installed pro e, and was asked for the code, I went to the txt file, and it let me continue to download the program. I have no problems letting you take a look at the code. Would you like to see the .dat file or my copy and pasted txt file from the email? Rob
Martin Hanák
