Summary: Does Pro/E have an easy way to verify a machined housing has a minimum wall thickness of .0
jgfrankusa
Pro Gurus:
Thank you all who reply.
Below is the summary of suggestions. For some reason I am unable to find
the hidden config in my WF 3 build M150. Without this enable I guess that I
won't be able to see the Thickness as others have suggested.
I will look into the Geomcaliper if the Thickness command can't be resolved.
Frank.
Note that the hidden config option will not show up in the find dialog
under the options menu that modified the config.pro.
Nor will it auto-compete the command in the option: box. You will have
to enter it in the Option: and Value: boxes. If it works your
confirmation will be the green 'light' in the options list.
It works on my WF5 M060 version.
Christopher F. Gosnell
FPD Company
124 Hidden Valley Road
McMurray, PA 15317
