Summary - Making a Family Table Instance its own Model
Highlighted
Topaz II
Here's how to do it without the rename:
- open the instance
- open the generic
- open the family table
- delete the line for that instance from the table
- select OK
- you should get a message that part abc.prt is no longer family table
driven
- close & erase the generic from session WITHOUT SAVING!  This is very
important if you want the instance to remain in the family table and
just need a copy to send to a vendor.
- return to the instance and save it
You should then have a stand alone part with the same name as the table
driven instance.  You'll want to move that file out of the directory
with the generic to avoid problems.
Doug Schaefer
LinkedIn
