TCP/IP Communication Ports
gkemner
Just yesterday Pro/E started taking 15-20 minutes to launch. Our
corporate IT dept made changes to the firewall on client machines and it
is now blocking TCP/IP communication with the server. I need a list of
all ports that Pro/E uses to communicate with the server so I can
configure the firewall to allow communication on those ports.
Any help would be appreciated!!
Greg,
Try opening a command prompt and type "netstat -b". This will give you a list of open ports and applications that are using them.
Patrick Williams | Sr. Applications Engineer | Engineering Systems | Steelcase Inc. | 616.698.4078 | My Site<">http://my.steelcase.com/Person.aspx?accountname=NA\PWILLIA3>
[cid:image001.jpg@01C9E43D.BCF34F90]
AllanS
(To:gkemner)
See TPI 34410 for ports used by Pro/INTRALINK.
