Table repeat regions, comments, and text style
MGortner
All:
I have a repeat region table (bill of materials) with comment cells and
the cells refuse to adhere to a defined text style. As soon as I type
in a new comment, all the cells in that column change their text style
to a size that is not the default.
This table is created from an existing table saved on our server. I've
tried setting my desired text style settings before saving this table
but it doesn't seem to help.
Does anyone know how to fix this?
Matt
Matt Gortner | Mechanical Engineer
CHASEDESIGN, LLC
1400 East Genesee Street | Skaneateles N.Y. 13152
315.685.1000 (p) | 315.685.5021 (f) | www.chasedesign.net
I'm just taking a guess. The drawing in which you are bringing the table in may not have the default text style setup as desired (your custom .dtl file was not applied). But for the tables saved in the server, instead of leaving the comment cells empty, add just a blank space, of course after setting up the desired text style. This way the cell will hold that text style irrespective of the text settings in the drawing. And yes, you will have to hit backspace every time you are adding a comment. Hope this helps.
