Table text settings
erine
Table text settings
When adding a new row or column to an existing table, I have to edit the text style to justify the horizontal/vertical orientation to middle/center and the character height.
What setting(s) should i alter to avoid doing this everytime?  I'm going through 200+ drawings that need a note changed and this revision block speedbump is killing my efficiency.
Creo 4.0 / M060
erine
(To:kdirth)
This works.  Figured that out after the first attempt at mapkeying the process.  My first attempt included recording the mapkey, switching between cells in the revision block and then after completing that, changing the sizing/orientation of the text in those cells. Second attempt, i manually entered the fields in the revision block, started recording the mapkey to resize/reorient and it worked on the next drawing.
It's definitely a workaround.  Not perfect, but this should speed things up a bit.
Creo 4.0 / M060
KenFarley
(To:erine)
This has been the situation forever, and I've never seen a solution. I, too, have to add the row, then change the properties of the new cells to match the ones in the rest of the table, etc. You can pick multiple cells (with <ctrl>-pick)and change them simultaneously, but it's still annoying.
erine
(To:KenFarley)
I tried making a mapkey to at least speed this up, but it does not work.  Odd that something this straight-forward would not have a fix.
Creo 4.0 / M060
kdirth
20-Turquoise
(To:erine)
A mapkey should be able to accomplish what you want to do.
Select the cell.
Start recording the map key.
Select properties from the RMB menu and change the text style, size and orientation.
Select OK then stop the mapkey recording.
To apply, select the cell then type the mapkey.
Be sure to save the mapkeys when you get it working so that it will be available tomarrow.
erine
(To:kdirth)
Creo 4.0 / M060
dhermosillo
(To:erine)
