Hi
I'm getting the following error message in my Creo 3.0, The option Mechanism_Design has not been acquired.
I do have the correct license and, everything else works, but for some reason this function wont.
Anyone have any ideas?
You need to reconfigure Creo 3.0 to get license for Mechanism_Design in startup configuration.
1. Execute reconfigure.exe from <Creo 3.0 install location>\parametric\bin
2. Select Next > Next > Customize
3. Select Command Configuration > Edit > Move Mechanism_design (License feature # 127) to right > Ok > Ok and Install.
This should correct the error.
You can also edit <Creo 3.0 install location>\parametric\bin\parametric.psf in Notepad.
Add 127 to get the following line:
ENV=CREOPMA_FEATURE_NAME=name_of_your_license (127)
Martin Hanak
Does the reply on your query help you to fix the error? If yes, mark the appropriate reply as correct answer.
