Alright gurus....
I've been out of the "Pro" world for a couple years and I'm getting older and my memory is failing. I've also did a seach on the forums and found nothing that helps.
I am trying to modify a drawing format but for some reason I cannot select the third angle projection symbol so that I can move it. I cannot pick on it, put a box around it, nothing.... What am I missing?
Thanks in advance!
Mike Thomason
Beverage-Air
Looks like we have a winner! I knew it was something simple that I was over looking! Thanks!
The symbol is likely in the format and not the drawing. Draft entities in the format are only visible in the drawing. You must modify the format to make those changes. Be aware, it will change it for all drawings using that format.
Darren Guidry
Supervisor - MCAD Systems and Design Support
General Atomics Aeronautical Systems, Inc.
