Tolerance Block Greyed out with tol_display set to yes in 2 places
AC_10454066
2-Explorer
I am using Creo Parametric Release 9.0 and Datecode9.0.2.0
My tolerance block is greyed out. I've updated the drawing properties to reflect tol_display set to yes, as well as going into the configuration file and setting tol_display to yes. This seems to be the fix from searching across the internet, but it's not fixing the issue for me.
2 REPLIES 2
You have to change your selection filter from Geometry to annotation.
You might want to read through this thread for a bit more info:
https://community.ptc.com/t5/3D-Part-Assembly-Design/HELP-Mapkey-to-record-edit-of-infamous-linear-tol-0-0-and/td-p/754584
If issue still persists, please attach a screenshot showing TOL that are greyed out.
