Transparent material and edge color
RaphMORIN
Hello all,
When I set a transparent material to a part, if I display that part in wireframe I can't see anything because edges have also a transparent color. Is it possible (config.pro option) to tell Creo that I don't want materials to affect edge color in Wireframe mode ? Thanks for you help.
I think, someone was talking about this a few weeks before but I can't find that discussion anymore.
Raphaël
Raphael,
It is due to color assigned in appearance plexi incolore, which is almost similar to white. If you will change the color edges will display or you can change the background color to custom scheme (e.g. as in older versions).
No hidden Display with older background:
10 REPLIES 10
Constantin
(To:RaphMORIN)
Hi Raphaël,
the only way I can think of is to assign a colour to the part and assign a different transparent material to the surfaces only.
This works if you want a edge colour different from the shading colour but I have not tried it with transparency...
StephenW
(To:RaphMORIN)
Try using SHADING WITH EDGES instead of just SHADE.
Go to VIEW tab - DISPLAY STYLE - SHADING WITH EDGES
Steve
Thanks for you answers.
@Constantin : the method you give should work but it happens to often to use this heavy method. Thanks
@Stephen : In fact I mostly use shading with edges, in this case no problem, the problem is only in hidden line or no hidden line. See screenshots below where I show a simple part in these 3 modes.
Shaded mode : no problem
Hidden line mode : we only see hidden lines
No hidden line mode : we can't see anything. I would like to see lines just as if no material was affected.
StephenW
(To:RaphMORIN)
That's an odd problem. I tested it on my system and transparency doesn't affect hidden line or no-hidden display.
How are you setting your color?
Raphael,
what can you see, when you set dark background ?
Martin Hanak
Martin Hanák
I made a try starting Creo without config.pro. I have the same result.
Martin, here's a screenshot of what I get with a dark background. It looks like the edges are white and this is the reason why I can't see them !!
Raphael,
you can upload your model (white brick), I can open it in my Creo installation to check its white color.
Martin Hanak
Martin Hanák
Here it is !
Raphael,
Ok, this is it ! In fact, the color affected to the material controls the edges color.
So, I can use any color different from my background color (in my case white), and set it transparent up to 99% and I still can see the edges. Thanks, I now just have to redefine a few materials I have in library.
