I am using Creo Parametric Release 7.0 and Datecode7.0.3.0
Good Morning dear,
I'm tryng to use de UDF tool, in assemble mode, to customize a project and the follow message shows:
"You have not checked out the license option. Please click "File->Options->Licensing" and choose required option from "Refresh license list".
In the part mode I can acess the tool.
I'm using a locked license.
Yep. For reference:
https://www.ptc.com/en/support/article/cs161119
https://www.ptc.com/en/support/article/cs352968
When I trie it the follow message show.
"There are no floating options currently accessible."
I'm using locked license.
You may need a floating license that is advanced assembly extension (AAX) or its equivalent to use the UDF functionality. Can you check on that and report back?
Yep. For reference:
