UI
bmozley
UI
Creo Community,
I have just finished customizing my ribbon interface and saved it to a
file. (creo_parametric_customization.ui). I have 8 users on a floating
license.
Is there an easy way to load this file on all my users machines, maybe
in the config.pro?
Brad
Creo 2.0 M010
BillChapman
(To:bmozley)
Rename this file creo_parametric_admin_customization.ui and put it in loadpoint\Common Files\M010\text
Customizing the UI in Creo is a nightmare.
You need to go into every mode in the software. I just found out, that activating a part or subassembly in an assembly is not the same as part or assembly mode. Even a skeleton part has its own mode compared to a normal part, but they are the same when activated in an assembly. Go figure....
When adding a general command like "Erase Not Displayed" to the quick access toolbar I would like to have a tickbox saying: All modes
/Bjarne
