I am using Creo Parametric Release 9.0 and Datecode9.0.4.0
Hello, I am having issues creating a bundle of wires. I have created the spools, designated the connectors, and successfully connected the connectors using wires, and I am able to create a bundle around a single wire. However, when I attempt to add wires to the bundle, I get an error message stating that it cannot be added to the bundle. I have reviewed all of the provided documentation on bundles, and the potential cause of this issue is not outlined. Can someone please help me identify any steps that I am missing in this process?
Here are the errors that I faced
Cable can not be added to bundle.
Hi Colte,
The wires to be added to the bundle should have a similar path as the bundle in order to add the wires to the bundle. Are the wires close to the bundle?
Amol Lungare
