Unable to connect to license server
NitMad
Creo is not able to fetch license from the license server. This is after connecting to Windchill via VPN. I am getting ping responses if i use the IP address but no response if i use hostname of the server. I have tried changing the server name in the ENV=PTC_D_LICENSE_FILE line of the parametric.psf file with no avail. What am I missing or doing wrong here?
1 REPLY 1
MartinHanak
(To:NitMad)
add new line to C:\Windows\System32\drivers\etc\hosts file for your license server.
For example:
192.168.56.123   LicenseServerName
Martin Hanák
