I had Windchill 12.0.2 with Creo 7.0.10 and CreoView Adapter 8.0 running where submitting a job by chedk-in would launch the adapter and publish the image.
Did an upgrade to Creo 9.0.5 and CreoView Adapter 9.1 the other day and now it won't start automatically. If I start the ProEworker on the Windchill server, I can use the Worker admin tool and start the publishing and then jobs publish. If the ProEworker is not started, the worker doesn't start. In either case, the icon says Executable Not Safe, but it does start with the worker already running.
I have double and triple checked the agent.ini file and the worker.exe.whitelist.prefixes setting to be sure both are spelled and capitalized exactly as Windows sees the folder names.
Anyone have some idea as to what to try next?
