To be safe, you can always run ptcsetup from the WF installation loadpoint on the client machine to make sure the appropriate .psf or .bat files is generated with the latest license file. Then you should be able to copy these to the other systems in the network.
Willy Chung
SurfaceInk Corporation - Boston
www.surfaceink.com
