Using the loopback adapter for FlexLM
gchampoux
I am preparing a standalone PC for a secure-room project.
It won't be on any network.
I'll be installing Pro/E WF3 and it's FlexLM services to support this one license.
I already know how to disable the mediasence so that the Ethernet port stays alive.
However, our secure-room admin would prefer to disable the Ethernet port.
He asked if we could use the Microsoft Loopback Adapter, which is a virtual network device.
Has anyone ever tried this and can share their experience?
Gerry Champoux Williams International
Lead Engineer 2280 E. West Maple Road
Information Technology Walled Lake, MI 48390
' (248) 960-2816 7 (248) 960-2607
* - * www.williams-int.com
I've done this in the past on Unix. All I did was set the IP address to
127.0.0.1. Basically turn DHCP off and manually set the IP as 127.0.0.1.
IP address 127.0.0.1 is the loopback device. I believe it should be the
same for Windows.
Paul
> one license.
> stays alive.
Paul Gress
President
Rad Electronics Inc.
3122 Expressway Drive South
Islandia, NY 11749
(631) 243-7707
(631) 243-7708 Fax
www.rad-electronics.com
Hi Gerry,
Yes, I've done this in the past. Check out http://support.microsoft.com/default.aspx?scid=kb;en-us;839013 for details on setting up the MS Loopback Adapter. When I did that in the past the MAC address was 02-xx-xx-xx-4F-50 on an HP Omnibook 6000 back in 2004, so I just submitted that for the appropriate License File. Let me know if you get the same MAC address or not, I'm curious how MS Loopback Adapter behaves.
Alternatively, can you install as a locked license and skip the License Server requirement?
Willy Chung
SurfaceInk Corporation - Boston
www.surfaceink.com
chung@surfaceink.com
In Reply to Gerry Champoux:
* - * www.williams-int.com http://www.williams-int.com
WILLIAMS INTERNATIONAL A COMPANY WITH A VISION
This email message and any attachment(s) are for the sole use of the intended
recipient(s) and may contain proprietary and/or confidential information which may
be privileged or otherwise protected from disclosure.
Any unauthorized review, use, disclosure or distribution is prohibited. If you are
not the intended recipient(s), please contact the sender by reply email and destroy
the original message and any copies of the message as well as any attachment(s)
to the original message.
This email message does not form a binding contract or contract amendment with
the sender, unless it clearly states in writing that it is a contract or contract amendment.
Willy,
Thank you!
Gerry
Attention: Creo 7.0 Customers
Please consider upgrading
End of Life announcement here.
