VPN problem after upgrade from 2.0 to 3.0
Staron
After we upgraded from 2.0 to 3.0, all users who use VPN, have not been able to connect to work using VPN. This did work “flawless” before the upgrade.
Anyone else been having this problem with 3.0, or have an idea?
Our version:
PTC CREO 3.0 M040
Windchill 10.2 M030
Added som pictures:
9 REPLIES 9
TomU
(To:Staron)
Yes, we have the exact same issue.  Creo 3 will NOT connect to Windchill over a VPN.  Earlier versions work fine.  We've had a case open for months now.  It's looking like it might have something to do with IPv4 vs. IPv6 binding, but still don't know for sure.  It's isn't as simple as just disabling IPv6.
Staron
(To:TomU)
Hi Tom and thanks for the quick reply.
For months you say, then it sounds like a very complicated problem, but hopefully there will be an solution shortly, as I work every other week home.
Staron
(To:TomU)
We got VPN to work here now.
Using the following:
Creo 3.0 M040
Creo Agent 3.103.0
There was some guy from PTC Support in Norway who helped us, what he did I can not say, but I have tested it from outside our company as it work as it should.
TomU
(To:Staron)
We too are functional now.  R&D provided a modified DLL (asyncoremt.dll) for Creo 3.0 M040 and Creo Agent 3.103.  Still haven't heard when this will be released to production.
By the way, in our case this was not specific to M040.  We have been unable to use Creo 3 with Windchill over a VPN for all the releases (M010 - M040).
Stale,
on the second picture Creo Agent is mentioned. Its version is 3.103 in case of Creo 3.0 M040.
My suggestion: Install Creo 3.0 M030 with Creo Agent 3.96 and just test if it is working via VPN. If it works then open Case at PTC Support and report that Creo Agent 3.103 does not work correctly.
Martin Hanak
Martin Hanák
Hi Martin, and thanks for reply.
I will tell our support technician to test this.
I will keep this post updated, in case anyone else are having this issue.
Stale
bfrandsen
6-Contributor
(To:Staron)
I just tested this VPN issue on Creo3 M040, Creo Platform Agent 3.103 using Chromium embedded browser against Windchill 10.1 M030 and had no issues.
This combination of Creo and Windchill is unsupported by PTC, so still using Creo 2 in production.
Bjarne
Hi Bjarne
I have forwarded this, thanks alot for the input.
Stale
chfi
6-Contributor
(To:Staron)
