Just switched to Creo Elements Pro 5 and i can't get vericut to work. Is it not supported by this version does anyone know? Checked all the config settings and it seem to be set right.
Jeff
Jeff,
If you just loaded Creo I would go back through the install and make sure the Vericut option is check marked.
Steve
Jeff,
Steve
Thanks again Steve!!!
