Vericut animation not working with Creo Elements Pro5
jeuclide
8-Gravel
Just switched to Creo Elements Pro 5 and i can't get vericut to work. Is it not supported by this version does anyone know? Checked all the config settings and it seem to be set right.
Jeff
SteveLucas
(To:jeuclide)
Jeff,
If you just loaded Creo I would go back through the install and make sure the Vericut option is check marked.
Steve
SteveLucas
(To:jeuclide)
Jeff,
Steve
Thanks again Steve!!!
