I can tell you, don't get the QUADRO 2000. I am having problems with it on a Dell T7500.
In Reply to Brian Lynn:
Out of the following options which would you choose with the requirement of being the most cost effective, which in this case means won't slow the user down or cause crashes but will be as cheap as possible.
Professional 2D Graphics Cards
512MB NVIDIA(r) Quadro(r) NVS 420, Quad Monitor, 4DVI [Included in Price]
512MB NVIDIA(r) Quadro(r) NVS 420, Quad Monitor, 4DP add $0.00
256MB NVIDIA(r) Quadro(r) NVS 295, 2MON, 2 DP w/ 2 DP to DVI Adapters [subtract $266.00]
256MB NVIDIA(r) Quadro(r) NVS 295, 2MON, 2 DP w/ 1 DP to DVI Adapter [subtract $273.00]
Dual 512MB NVIDIA(r) Quadro(r) NVS 420, 8 Monitor, 8DVI [add $350.00]
Dual 512MB NVIDIA(r) Quadro(r) NVS 420, 8 Monitor, 8DP [add $350.00]
Dual 256MB NVIDIA(r) Quadro(r) NVS 295, 4MON, 4DP w/ 4DP to DVI Adapt [subtract $168.00]
256MB ATI FireMV(r) 2260, 2MON, 2 DP w/ 2 DP to DVI Adapter [subtract $273.00]
Dual 256MB ATI FireMV(r) 2260, 4MON, 4 DP w/ 4 DP to DVI Adapter [subtract $182.00]
256MB ATI FireMV(r) 2260, 2MON, 2 DP w/ 1 DP to DVI Adapter [subtract $273.00]
High End 3D Graphics Cards
2.5GB NVIDIA(r) Quadro(r) 5000, DUAL MON, 2DP & 1DVI [add $1,309.00]
2.0GB AMD FirePro(tm) V7900, Triple Monitor, 4 DP [add $476.00]
6.0GB NVIDIA(r) Quadro(r) 6000, Dual MON, 2 DP & 1 DVI [add $3,122.00]
Dual 2.5GB NVIDIA(r) Quadro(r) 5000, QUAD MON, 4DP & 2DVI [add $2,751.00]
Mid Range 3D Graphics Cards
2GB NVIDIA(r) Quadro(r) 4000, DUAL MON, 2DP & 1DVI [add $539.00]
1.0GB NVIDIA(r) Quadro(r) 2000, Dual MON, 2 DP & 1 DVI [add $269.50]
2.0GB AMD FirePro(tm) V5900, Triple Monitor, 2DP & 1DVI [add $203.00]
2.0GB ATI FirePro(tm) V7800, Triple MON, 2 DP & 1 DVI [add $441.00]
Dual 2.0GB ATI FirePro(tm) V7800, Six MON, 4 DP & 2 DVI [add $1,015.00]
Dual 2.0GB AMD FirePro(tm) V7900, Six Monitor, 8 DP [add $1,085.00]
Dual 2GB NVIDIA(r) Quadro(r) 4000, DUAL MON, 2DP & 1DVI [add $1,211.00]
Dual 1.0GB NVIDIA(r) Quadro(r) 2000, Quad MON, 4 DP & 2 DVI [add $672.00]
Dual 2.0GB AMD FirePro(tm) V5900, Six Monitor, 4DP & 2DVI [add $539.00]
Entry 3D Graphics Cards
512MB NVIDIA(r) Quadro(r) FX 580, DUAL MON, 2 DP & 1 DVI [Included in Price]
Dual 512MB NVIDIA(r) Quadro(r) FX 580, QUAD MON, 4DP & 2DVI [add $126.00]
1.0GB NVIDIA(r) Quadro(r) 600, Dual MON, 1 DP & 1 DVI add $0.00
Dual 1.0GB NVIDIA(r) Quadro(r) 600, Quad MON, 2 DP & 2 DVI
Thank you for your recommendations,
[cid:image001.jpg@01CC3259.FFBDAAC0]
The information contained in this electronic mail transmission is intended by Weil-McLain & for the use of the named individual or entity to which it is directed and may contain information that is confidential or privileged. If you have received this electronic mail transmission in error, please notify the sender of the error by reply email so that the sender's address records can be corrected and delete it from your system without copying or forwarding it, including any reply records.
