I have changed the view scale denominator in the config.pro file to 60.
I have some drawings created before I changed this.
In the bottom left corner it says a value that is ok but in the drawing sheet the value has the old format.
Does someone know how to solve this?
Claes,
Martin Hanak
Yes, you are right. I changed it in the detail option file.
I tried to change the settings for existing drawing this way:
Prepare, Drawing properties->Detail options
It says that view_scale_denominator value is 60.
When I double click my only view and select scale the value is:
Default to sheet (1:3)
But my sheet still says 3:20!
Claes,
OK, view_scale_denominator is set properly. Now you have to modify scale value. What value do you want to see on your drawing ? Upload a picture, if the problem persists after modification.
Martin Hanak
I modified scale value to different values.(1:1, 1:2 1:3)
But whatever i set it to, the drawing sheet still says it is 3:20!
It seems like the sheet have lost its link or something.
Is there any way to reload it or?
Claes,
did you double-clicked the value 3:20 inside the window and did you modify it ?
Martin Hanak
No, I haven´t changed it manually (as far as I can remember).
Nothing happens if I try to doubleclick it.
Claes,
can you upload some picture ?
click Use advanced editor link (top right corner of Reply window) to be able to Browse and attach the file containing the picture.
Martin Hanak
