WF 2 Model Check on Network
Moonstone
Okay, I have model check working with the standard directory on the local drive. Now I would like to push it out to the users but have them point to the network drive so I only have to worry about the files in one location. However, I cannot get the MCDIR$ environment variable to work. I have it pointing to the level above the config folder, from what I gathered from other posts and PTC support,on the network drive. I was able to do this awhile ago with 2001, but just cannot seem to figure it out. Any help will be appreciated.
Thank you,
Brian Toussaint
CAD Administrator
Hoshizaki America
Summary: WF 2 Model Check on Network
Thank you to Robert for the answer.
Answer:
This is what I have at the end of our .PSF files ....
// USER - PSF
// Add User specific environment or run applications below here
ENV=MCDIR=W:\MCAE\modelcheck
I ended up with ENV=MCDIR=\\<our server=" name=">\<folder name=" where=" the<br="/>config folder is located>
Why tech support couldn't tell me this, or any of the help files. That
will be an easy file to push out.
Sincerely,
Brian Toussaint
CAD Administrator
618 Hwy. 74 S., Peachtree City, GA 30269
